mixont70706
I am testing connection to the server through a VPN connection. What I have noticed is, I can run the client manually and it will connect to the server and it reports that it is there but not scanned. I have checked all firewall settings and the ports are opened for 2-way communication. Can you please shed some light on the problem?
Thank you
Terry
mixont70706
I got it figured out, it was a reverse look up probelm. Thank you for all your help.
So with the connectiontester you can connect to the client on ipaddress and it doesn't give you any errors?
mixont70706
Yes to all the above.
The error that I am getting is
Wmierror The RPC server is unavailable
Andreasl
Do you try the connectiontester from server to client? Can you ping the name of the client? Is dns working for resolving the client name?
