‎05-01-2025 05:25 PM
I am trying to create a Lansweeper report that includes group membership of a specific group and each user in that groups manager's email. Is this possible? Any help would be appreciated.
User-Generated Reports
‎05-02-2025 01:33 AM
Hi
We have added a sample report that will get you started.
Instructions for adding this report to your Lansweeper installation can be found here: https://www.lansweeper.com/knowledgebase/how-to-add-a-report-to-your-lansweeper-installation/
If you are interested in building or modifying reports, we do recommend:
- Reviewing some SQL tutorials, as the Lansweeper report builder is a standard SQL editor. If you know SQL, you know how to build Lansweeper reports as well. This seems like a good tutorial: https://www.w3schools.com/sql/
- Making use of our database dictionary, which explains in great detail what each database table and field stores. More information on the dictionary can be found here: https://www.lansweeper.com/knowledgebase/accessing-the-lansweeper-database-documentation/
- Checking out our report library: https://www.lansweeper.com/report/
tblAssets.AssetID,
tblAssets.Domain,
tblAssets.Username,
tblAssets.Userdomain,
tblAssets.IPAddress,
tblAssets.Firstseen,
tblAssets.Lastseen,
tblAssets.Lasttried,
tsysOS.OSname
From tblAssets
Where tblAssets.AssetID Not In (Select tblADComputers.AssetID
From tblADComputers Left Join tblADMembership
On tblADMembership.ChildAdObjectID = tblADComputers.ADObjectID Left Join
tblADGroups On tblADMembership.ParentAdObjectID = tblADGroups.ADObjectID
Where tblADGroups.Name Like 'SP-%') And tblAssets.AssetID Not In (Select
Where tblADGroups.Name Like 'Baseline-%') And tblAssetCustom.State = 1 And
tblComputersystem.PartOfDomain = 1
Order By tblAssets.Domain,
tblAssets.AssetName
