LithiumKid1976
hi
i just have 2 questions about the "wake on lan" function.
i get the "error file not found" when i try to run it from the action screen.
i know i have added custom actions before under custom actions, but do i add it there or is it to be added some where else?? ie "vendor support" and "custom actions" have thier own tabs, is there a specific area for "Network Wake On Lan"
and also will wol work for pcs in diffrent subnets?
7 REPLIES 7
Lansweeper configuration tools/configuration/Wake on Lan
crashcarr
How do I modify where the Wake on Lan link points to wol.exe in 4.0?
talubu
Hello, I've just install Lansweeper premium. I cann't find wol.exe file, please help.
Thanks.
Thanks.
Download from http://www.lansweeper.com/actions.zip
In 3.5.x the wol.exe is hardcoded, to make it work place wol.exe in your windows folder.
4.0 will let you choose the location.
LithiumKid1976
hi
when i try to use it though, i get the file not found error mentioned above, even thought the wol.exe is located at \\servername\lstools
so how can i get it to work, as its not working at all at the minute?
version 3.5 uses wol.exe by default, in version 4.0 (currently in beta) you will be able to change this.
