notnoisy
I have installed Lansweeper on Windows Server 2003 SBS. All seems to work ok. Service is started, database setup, virtual directory in IIS setup.
But when I open the lansweeper webconsole (http://localhost/lansweeper) I get the following error in all three frames:
Server Error in '/' Application.
Parser Error
Description: An error occurred during the parsing of a resource required to service this request. Please review the following specific parse error details and modify your source file appropriately.
Parser Error Message: File or assembly name DreamweaverCtrls, or one of its dependencies, was not found.
Source Error:
Line 1: <%@ Page Language="VB" ContentType="text/html" %>
Line 2: <%@ Register TagPrefix="MM" Namespace="DreamweaverCtrls" Assembly="DreamweaverCtrls,version=1.0.0.0,publicKeyToken=836f606ede05d46a,culture=neutral" %>
Line 3: <MM:DataSet
Line 4: runat="Server"
Source File: C:\Program Files\LanSweeper\Webconsole\logoninfo.aspx Line: 2
Assembly Load Trace: The following information can be helpful to determine why the assembly 'DreamweaverCtrls' could not be loaded.
=== Pre-bind state information ===
LOG: DisplayName = DreamweaverCtrls, Version=1.0.0.0, Culture=neutral, PublicKeyToken=836f606ede05d46a
(Fully-specified)
LOG: Appbase = file:///c:/inetpub/wwwroot
LOG: Initial PrivatePath = bin
Calling assembly : (Unknown).
LOG: Publisher policy file is not found.
LOG: No redirect found in host configuration file (C:\WINDOWS\Microsoft.NET\Framework\v1.1.4322\aspnet.config).
LOG: Using machine configuration file from C:\WINDOWS\Microsoft.NET\Framework\v1.1.4322\config\machine.config.
LOG: Post-policy reference: DreamweaverCtrls, Version=1.0.0.0, Culture=neutral, PublicKeyToken=836f606ede05d46a
LOG: Attempting download of new URL file:///C:/WINDOWS/Microsoft.NET/Framework/v1.1.4322/Temporary ASP.NET Files/root/2135a508/8d69a834/DreamweaverCtrls.DLL.
LOG: Attempting download of new URL file:///C:/WINDOWS/Microsoft.NET/Framework/v1.1.4322/Temporary ASP.NET Files/root/2135a508/8d69a834/DreamweaverCtrls/DreamweaverCtrls.DLL.
LOG: Attempting download of new URL file:///c:/inetpub/wwwroot/bin/DreamweaverCtrls.DLL.
LOG: Attempting download of new URL file:///c:/inetpub/wwwroot/bin/DreamweaverCtrls/DreamweaverCtrls.DLL.
LOG: Attempting download of new URL file:///C:/WINDOWS/Microsoft.NET/Framework/v1.1.4322/Temporary ASP.NET Files/root/2135a508/8d69a834/DreamweaverCtrls.EXE.
LOG: Attempting download of new URL file:///C:/WINDOWS/Microsoft.NET/Framework/v1.1.4322/Temporary ASP.NET Files/root/2135a508/8d69a834/DreamweaverCtrls/DreamweaverCtrls.EXE.
LOG: Attempting download of new URL file:///c:/inetpub/wwwroot/bin/DreamweaverCtrls.EXE.
LOG: Attempting download of new URL file:///c:/inetpub/wwwroot/bin/DreamweaverCtrls/DreamweaverCtrls.EXE.
Version Information: Microsoft .NET Framework Version:1.1.4322.2379; ASP.NET Version:1.1.4322.2379
Do I have to install some Dreamweaver component or what?
Sorry for the late response
You need to add the "DreamweaverCtrls.DLL" file to the bin folder of your webroot
If "lansweeper" is a virtual directory, it should be under http://localhost/lansweeper/bin
otherwise it should be under http://localhost/bin
(me guess is that you didn't create a virtual directory)
