dukedizel
Access is denied 0x80070005 (blablabla.domain.ru, blablabla, 10.78.3.72)
I've tried all the ways here: http://www.lansweeper.com/kb/WMI-Access-is-denied.aspx
Nothing has helped.
Report WMIDiag.vbs
28156 11:23:53 (0) ** WMIDiag v2.1 started on 14 марта 2012 г. at 11:19.
28157 11:23:53 (0) **
28158 11:23:53 (0) ** Copyright (c) Microsoft Corporation. All rights reserved - July 2007.
28159 11:23:53 (0) **
28160 11:23:53 (0) ** This script is not supported under any Microsoft standard support program or service.
28161 11:23:53 (0) ** The script is provided AS IS without warranty of any kind. Microsoft further disclaims all
28162 11:23:53 (0) ** implied warranties including, without limitation, any implied warranties of merchantability
28163 11:23:53 (0) ** or of fitness for a particular purpose. The entire risk arising out of the use or performance
28164 11:23:53 (0) ** of the scripts and documentation remains with you. In no event shall Microsoft, its authors,
28165 11:23:53 (0) ** or anyone else involved in the creation, production, or delivery of the script be liable for
28166 11:23:53 (0) ** any damages whatsoever (including, without limitation, damages for loss of business profits,
28167 11:23:53 (0) ** business interruption, loss of business information, or other pecuniary loss) arising out of
28168 11:23:53 (0) ** the use of or inability to use the script or documentation, even if Microsoft has been advised
28169 11:23:53 (0) ** of the possibility of such damages.
28170 11:23:53 (0) **
28171 11:23:53 (0) **
28172 11:23:53 (0) ** ----------------------------------------------------------------------------------------------------------------------------------
28173 11:23:53 (0) ** ----------------------------------------------------- WMI REPORT: BEGIN ----------------------------------------------------------
28174 11:23:53 (0) ** ----------------------------------------------------------------------------------------------------------------------------------
28175 11:23:53 (0) **
28176 11:23:53 (0) ** ----------------------------------------------------------------------------------------------------------------------------------
28177 11:23:53 (0) ** Windows 7 - Service Pack 1 - 64-bit (7601) - User 'SHUVOE\PISKUNOVDV' on computer 'WSPISKUNOV1'.
28178 11:23:53 (0) ** ----------------------------------------------------------------------------------------------------------------------------------
28179 11:23:53 (0) ** INFO: Environment: .................................................................................................. 1 ITEM(S)!
28180 11:23:53 (0) ** INFO: => 2 possible incorrect shutdown(s) detected on:
28181 11:23:53 (0) ** - Shutdown on 14 December 2011 13:21:23 (GMT-0).
28182 11:23:53 (0) ** - Shutdown on 31 January 2012 04:45:10 (GMT-0).
28183 11:23:53 (0) **
28184 11:23:53 (0) ** System drive: ....................................................................................................... C: (Disk #0 Partition #1).
28185 11:23:53 (0) ** Drive type: ......................................................................................................... IDE (ST250DM000-1BD141 ATA Device).
28186 11:23:53 (0) ** There are no missing WMI system files: .............................................................................. OK.
28187 11:23:53 (0) ** There are no missing WMI repository files: .......................................................................... OK.
28188 11:23:53 (0) ** WMI repository state: ............................................................................................... CONSISTENT.
28189 11:23:53 (0) ** AFTER running WMIDiag:
28190 11:23:53 (0) ** The WMI repository has a size of: ................................................................................... 26 MB.
28191 11:23:53 (0) ** - Disk free space on 'C:': .......................................................................................... 15179 MB.
28192 11:23:53 (0) ** - INDEX.BTR, 4587520 bytes, 14.03.2012 11:20:47
28193 11:23:53 (0) ** - MAPPING1.MAP, 62944 bytes, 14.03.2012 11:08:47
28194 11:23:53 (0) ** - MAPPING2.MAP, 62964 bytes, 14.03.2012 11:09:17
28195 11:23:53 (0) ** - OBJECTS.DATA, 22921216 bytes, 14.03.2012 11:20:47
28196 11:23:53 (0) ** ----------------------------------------------------------------------------------------------------------------------------------
28197 11:23:53 (2) !! WARNING: Windows Firewall: .......................................................................................... DISABLED.
28198 11:23:53 (0) ** ----------------------------------------------------------------------------------------------------------------------------------
28199 11:23:53 (0) ** DCOM Status: ........................................................................................................ OK.
28200 11:23:53 (0) ** WMI registry setup: ................................................................................................. OK.
28201 11:23:53 (0) ** INFO: WMI service has dependents: ................................................................................... 2 SERVICE(S)!
28202 11:23:53 (0) ** - Security Center (WSCSVC, StartMode='Automatic')
28203 11:23:53 (0) ** - Internet Connection Sharing (ICS) (SHAREDACCESS, StartMode='Disabled')
28204 11:23:53 (0) ** => If the WMI service is stopped, the listed service(s) will have to be stopped as well.
28205 11:23:53 (0) ** Note: If the service is marked with (*), it means that the service/application uses WMI but
28206 11:23:53 (0) ** there is no hard dependency on WMI. However, if the WMI service is stopped,
28207 11:23:53 (0) ** this can prevent the service/application to work as expected.
28208 11:23:53 (0) **
28209 11:23:53 (0) ** RPCSS service: ...................................................................................................... OK (Already started).
28210 11:23:53 (0) ** WINMGMT service: .................................................................................................... OK (Already started).
28211 11:23:53 (0) ** ----------------------------------------------------------------------------------------------------------------------------------
28212 11:23:53 (0) ** WMI service DCOM setup: ............................................................................................. OK.
28213 11:23:53 (0) ** WMI components DCOM registrations: .................................................................................. OK.
28214 11:23:53 (0) ** WMI ProgID registrations: ........................................................................................... OK.
28215 11:23:53 (0) ** WMI provider DCOM registrations: .................................................................................... OK.
28216 11:23:53 (0) ** WMI provider CIM registrations: ..................................................................................... OK.
28217 11:23:53 (0) ** WMI provider CLSIDs: ................................................................................................ OK.
28218 11:23:53 (0) ** WMI providers EXE/DLL availability: ................................................................................. OK.
28219 11:23:53 (0) ** ----------------------------------------------------------------------------------------------------------------------------------
28220 11:23:53 (0) ** INFO: User Account Control (UAC): ................................................................................... DISABLED.
28221 11:23:53 (0) ** INFO: Local Account Filtering: ...................................................................................... ENABLED.
28222 11:23:53 (0) ** => WMI tasks remotely accessing WMI information on this computer and requiring Administrative
28223 11:23:53 (0) ** privileges MUST use a DOMAIN account part of the Local Administrators group of this computer
28224 11:23:53 (0) ** to ensure that administrative privileges are granted. If a Local User account is used for remote
28225 11:23:53 (0) ** accesses, it will be reduced to a plain user (filtered token), even if it is part of the Local Administrators group.
28226 11:23:53 (0) **
28227 11:23:53 (0) ** DCOM security for 'Microsoft WMI Provider Subsystem Host' (Launch & Activation Permissions): ........................ MODIFIED.
28228 11:23:53 (1) !! ERROR: Default trustee 'BUILTIN\ADMINISTRATORS' has been REMOVED!
28229 11:23:53 (0) ** - REMOVED ACE:
28230 11:23:53 (0) ** ACEType: &h0
28231 11:23:53 (0) ** ACCESS_ALLOWED_ACE_TYPE
28232 11:23:53 (0) ** ACEFlags: &h0
28233 11:23:53 (0) ** ACEMask: &h1F
28234 11:23:53 (0) ** DCOM_RIGHT_EXECUTE
28235 11:23:53 (0) ** DCOM_RIGHT_LAUNCH_LOCAL
28236 11:23:53 (0) ** DCOM_RIGHT_LAUNCH_REMOTE
28237 11:23:53 (0) ** DCOM_RIGHT_ACTIVATE_LOCAL
28238 11:23:53 (0) ** DCOM_RIGHT_ACTIVATE_REMOTE
28239 11:23:53 (0) **
28240 11:23:53 (0) ** => The REMOVED ACE was part of the DEFAULT setup for the trustee.
28241 11:23:53 (0) ** Removing default security will cause some operations to fail!
28242 11:23:53 (0) ** It is possible to fix this issue by editing the security descriptor and adding the ACE.
28243 11:23:53 (0) ** For DCOM objects, this can be done with 'DCOMCNFG.EXE'.
28244 11:23:53 (0) **
28245 11:23:53 (0) ** DCOM security for 'Microsoft WMI Provider Subsystem Host' (Launch & Activation Permissions): ........................ MODIFIED.
28246 11:23:53 (1) !! ERROR: Default trustee 'NT AUTHORITY\INTERACTIVE' has been REMOVED!
28247 11:23:53 (0) ** - REMOVED ACE:
28248 11:23:53 (0) ** ACEType: &h0
28249 11:23:53 (0) ** ACCESS_ALLOWED_ACE_TYPE
28250 11:23:53 (0) ** ACEFlags: &h0
28251 11:23:53 (0) ** ACEMask: &h1F
28252 11:23:53 (0) ** DCOM_RIGHT_EXECUTE
28253 11:23:53 (0) ** DCOM_RIGHT_LAUNCH_LOCAL
28254 11:23:53 (0) ** DCOM_RIGHT_LAUNCH_REMOTE
28255 11:23:53 (0) ** DCOM_RIGHT_ACTIVATE_LOCAL
28256 11:23:53 (0) ** DCOM_RIGHT_ACTIVATE_REMOTE
28257 11:23:53 (0) **
28258 11:23:53 (0) ** => The REMOVED ACE was part of the DEFAULT setup for the trustee.
28259 11:23:53 (0) ** Removing default security will cause some operations to fail!
28260 11:23:53 (0) ** It is possible to fix this issue by editing the security descriptor and adding the ACE.
28261 11:23:53 (0) ** For DCOM objects, this can be done with 'DCOMCNFG.EXE'.
28262 11:23:53 (0) **
28263 11:23:53 (0) **
28264 11:23:53 (0) ** DCOM security warning(s) detected: .................................................................................. 0.
28265 11:23:53 (0) ** DCOM security error(s) detected: .................................................................................... 2.
28266 11:23:53 (0) ** WMI security warning(s) detected: ................................................................................... 0.
28267 11:23:53 (0) ** WMI security error(s) detected: ..................................................................................... 0.
28268 11:23:53 (0) **
28269 11:23:53 (1) !! ERROR: Overall DCOM security status: ................................................................................ ERROR!
28270 11:23:53 (0) ** Overall WMI security status: ........................................................................................ OK.
28271 11:23:53 (0) ** - Started at 'Root' --------------------------------------------------------------------------------------------------------------
28272 11:23:53 (0) ** INFO: WMI permanent SUBSCRIPTION(S): ................................................................................ 1.
28273 11:23:53 (0) ** - ROOT/SUBSCRIPTION, NTEventLogEventConsumer.Name="SCM Event Log Consumer".
28274 11:23:53 (0) ** 'select * from MSFT_SCMEventLogEvent'
28275 11:23:53 (0) **
28276 11:23:53 (0) ** WMI TIMER instruction(s): ........................................................................................... NONE.
28277 11:23:53 (0) ** INFO: WMI namespace(s) requiring PACKET PRIVACY: .................................................................... 3 NAMESPACE(S)!
28278 11:23:53 (0) ** - ROOT/CIMV2/SECURITY/MICROSOFTTPM.
28279 11:23:53 (0) ** - ROOT/CIMV2/TERMINALSERVICES.
28280 11:23:53 (0) ** - ROOT/SERVICEMODEL.
28281 11:23:53 (0) ** => When remotely connecting, the namespace(s) listed require(s) the WMI client to
28282 11:23:53 (0) ** use an encrypted connection by specifying the PACKET PRIVACY authentication level.
28283 11:23:53 (0) ** (RPC_C_AUTHN_LEVEL_PKT_PRIVACY or PktPrivacy flags)
28284 11:23:53 (0) ** i.e. 'WMIC.EXE /NODE:"WSPISKUNOV1" /AUTHLEVEL:Pktprivacy /NAMESPACE:\\ROOT\SERVICEMODEL Class __SystemSecurity'
28285 11:23:53 (0) **
28286 11:23:53 (0) ** WMI MONIKER CONNECTIONS: ............................................................................................ OK.
28287 11:23:53 (0) ** WMI CONNECTIONS: .................................................................................................... OK.
28288 11:23:53 (1) !! ERROR: WMI GET operation errors reported: ........................................................................... 30 ERROR(S)!
28289 11:23:53 (0) ** - Root/CIMV2, MSFT_NetInvalidDriverDependency, 0x80041002 - (WBEM_E_NOT_FOUND) Object cannot be found.
28290 11:23:53 (0) ** MOF Registration: ''
28291 11:23:53 (0) ** - Root/CIMV2, Win32_OsBaselineProvider, 0x80041002 - (WBEM_E_NOT_FOUND) Object cannot be found.
28292 11:23:53 (0) ** MOF Registration: ''
28293 11:23:53 (0) ** - Root/CIMV2, Win32_OsBaseline, 0x80041002 - (WBEM_E_NOT_FOUND) Object cannot be found.
28294 11:23:53 (0) ** MOF Registration: ''
28295 11:23:53 (0) ** - Root/CIMV2, Win32_DriverVXD, 0x80041002 - (WBEM_E_NOT_FOUND) Object cannot be found.
28296 11:23:53 (0) ** MOF Registration: ''
28297 11:23:53 (0) ** - Root/CIMV2, Win32_PerfFormattedData_Counters_GenericIKEandAuthIP, 0x80041002 - (WBEM_E_NOT_FOUND) Object cannot be found.
28298 11:23:53 (0) ** MOF Registration: ''
28299 11:23:53 (0) ** - Root/CIMV2, Win32_PerfRawData_Counters_GenericIKEandAuthIP, 0x80041002 - (WBEM_E_NOT_FOUND) Object cannot be found.
28300 11:23:53 (0) ** MOF Registration: ''
28301 11:23:53 (0) ** - Root/CIMV2, Win32_PerfFormattedData_Counters_IPsecAuthIPv4, 0x80041002 - (WBEM_E_NOT_FOUND) Object cannot be found.
28302 11:23:53 (0) ** MOF Registration: ''
28303 11:23:53 (0) ** - Root/CIMV2, Win32_PerfRawData_Counters_IPsecAuthIPv4, 0x80041002 - (WBEM_E_NOT_FOUND) Object cannot be found.
28304 11:23:53 (0) ** MOF Registration: ''
28305 11:23:53 (0) ** - Root/CIMV2, Win32_PerfFormattedData_Counters_IPsecAuthIPv6, 0x80041002 - (WBEM_E_NOT_FOUND) Object cannot be found.
28306 11:23:53 (0) ** MOF Registration: ''
28307 11:23:53 (0) ** - Root/CIMV2, Win32_PerfRawData_Counters_IPsecAuthIPv6, 0x80041002 - (WBEM_E_NOT_FOUND) Object cannot be found.
28308 11:23:53 (0) ** MOF Registration: ''
28309 11:23:53 (0) ** - Root/CIMV2, Win32_PerfFormattedData_Counters_IPsecIKEv4, 0x80041002 - (WBEM_E_NOT_FOUND) Object cannot be found.
28310 11:23:53 (0) ** MOF Registration: ''
28311 11:23:53 (0) ** - Root/CIMV2, Win32_PerfRawData_Counters_IPsecIKEv4, 0x80041002 - (WBEM_E_NOT_FOUND) Object cannot be found.
28312 11:23:53 (0) ** MOF Registration: ''
28313 11:23:53 (0) ** - Root/CIMV2, Win32_PerfFormattedData_Counters_IPsecIKEv6, 0x80041002 - (WBEM_E_NOT_FOUND) Object cannot be found.
28314 11:23:53 (0) ** MOF Registration: ''
28315 11:23:53 (0) ** - Root/CIMV2, Win32_PerfRawData_Counters_IPsecIKEv6, 0x80041002 - (WBEM_E_NOT_FOUND) Object cannot be found.
28316 11:23:53 (0) ** MOF Registration: ''
28317 11:23:53 (0) ** - Root/CIMV2, Win32_PerfFormattedData_TermService_TerminalServices, 0x80041002 - (WBEM_E_NOT_FOUND) Object cannot be found.
28318 11:23:53 (0) ** MOF Registration: ''
28319 11:23:53 (0) ** - Root/CIMV2, Win32_PerfRawData_TermService_TerminalServices, 0x80041002 - (WBEM_E_NOT_FOUND) Object cannot be found.
28320 11:23:53 (0) ** MOF Registration: ''
28321 11:23:53 (0) ** - Root/WMI, ReserveDisjoinThread, 0x80041002 - (WBEM_E_NOT_FOUND) Object cannot be found.
28322 11:23:53 (0) ** MOF Registration: ''
28323 11:23:53 (0) ** - Root/WMI, ReserveLateCount, 0x80041002 - (WBEM_E_NOT_FOUND) Object cannot be found.
28324 11:23:53 (0) ** MOF Registration: ''
28325 11:23:53 (0) ** - Root/WMI, ReserveJoinThread, 0x80041002 - (WBEM_E_NOT_FOUND) Object cannot be found.
28326 11:23:53 (0) ** MOF Registration: ''
28327 11:23:53 (0) ** - Root/WMI, ReserveDelete, 0x80041002 - (WBEM_E_NOT_FOUND) Object cannot be found.
28328 11:23:53 (0) ** MOF Registration: ''
28329 11:23:53 (0) ** - Root/WMI, ReserveBandwidth, 0x80041002 - (WBEM_E_NOT_FOUND) Object cannot be found.
28330 11:23:53 (0) ** MOF Registration: ''
28331 11:23:53 (0) ** - Root/WMI, ReserveCreate, 0x80041002 - (WBEM_E_NOT_FOUND) Object cannot be found.
28332 11:23:53 (0) ** MOF Registration: ''
28333 11:23:53 (0) ** - Root/WMI, SystemConfig_PhyDisk, 0x80041002 - (WBEM_E_NOT_FOUND) Object cannot be found.
28334 11:23:53 (0) ** MOF Registration: ''
28335 11:23:53 (0) ** - Root/WMI, SystemConfig_Video, 0x80041002 - (WBEM_E_NOT_FOUND) Object cannot be found.
28336 11:23:53 (0) ** MOF Registration: ''
28337 11:23:53 (0) ** - Root/WMI, SystemConfig_IDEChannel, 0x80041002 - (WBEM_E_NOT_FOUND) Object cannot be found.
28338 11:23:53 (0) ** MOF Registration: ''
28339 11:23:53 (0) ** - Root/WMI, SystemConfig_NIC, 0x80041002 - (WBEM_E_NOT_FOUND) Object cannot be found.
28340 11:23:53 (0) ** MOF Registration: ''
28341 11:23:53 (0) ** - Root/WMI, SystemConfig_Network, 0x80041002 - (WBEM_E_NOT_FOUND) Object cannot be found.
28342 11:23:53 (0) ** MOF Registration: ''
28343 11:23:53 (0) ** - Root/WMI, SystemConfig_CPU, 0x80041002 - (WBEM_E_NOT_FOUND) Object cannot be found.
28344 11:23:53 (0) ** MOF Registration: ''
28345 11:23:53 (0) ** - Root/WMI, SystemConfig_LogDisk, 0x80041002 - (WBEM_E_NOT_FOUND) Object cannot be found.
28346 11:23:53 (0) ** MOF Registration: ''
28347 11:23:53 (0) ** - Root/WMI, SystemConfig_Power, 0x80041002 - (WBEM_E_NOT_FOUND) Object cannot be found.
28348 11:23:53 (0) ** MOF Registration: ''
28349 11:23:53 (0) ** => When a WMI performance class is missing (i.e. 'Win32_PerfRawData_TermService_TerminalServices'), it is generally due to
28350 11:23:53 (0) ** a lack of buffer refresh of the WMI class provider exposing the WMI performance counters.
28351 11:23:53 (0) ** You can refresh the WMI class provider buffer with the following command:
28352 11:23:53 (0) **
28353 11:23:53 (0) ** i.e. 'WINMGMT.EXE /SYNCPERF'
28354 11:23:53 (0) **
28355 11:23:53 (0) ** WMI MOF representations: ............................................................................................ OK.
28356 11:23:53 (0) ** WMI QUALIFIER access operations: .................................................................................... OK.
28357 11:23:53 (0) ** WMI ENUMERATION operations: ......................................................................................... OK.
28358 11:23:53 (0) ** WMI EXECQUERY operations: ........................................................................................... OK.
28359 11:23:53 (1) !! ERROR: WMI GET VALUE operation errors reported: ..................................................................... 1 ERROR(S)!
28360 11:23:53 (0) ** - Root/CIMV2, Instance: Win32_Service='WSCSVC', Property: Displayname='Центр обеспечения безопасности' (Expected default='Security Center').
28361 11:23:53 (0) **
28362 11:23:53 (0) ** WMI WRITE operations: ............................................................................................... NOT TESTED.
28363 11:23:53 (0) ** WMI PUT operations: ................................................................................................. NOT TESTED.
28364 11:23:53 (0) ** WMI DELETE operations: .............................................................................................. NOT TESTED.
28365 11:23:53 (0) ** WMI static instances retrieved: ..................................................................................... 2258.
28366 11:23:53 (0) ** WMI dynamic instances retrieved: .................................................................................... 0.
28367 11:23:53 (0) ** WMI instance request cancellations (to limit performance impact): ................................................... 1.
28368 11:23:53 (0) ** ----------------------------------------------------------------------------------------------------------------------------------
28369 11:23:53 (0) ** # of Event Log events BEFORE WMIDiag execution since the last 20 day(s):
28370 11:23:53 (0) ** DCOM: ............................................................................................................. 0.
28371 11:23:53 (0) ** WINMGMT: .......................................................................................................... 0.
28372 11:23:53 (0) ** WMIADAPTER: ....................................................................................................... 0.
28373 11:23:53 (0) **
28374 11:23:53 (0) ** # of additional Event Log events AFTER WMIDiag execution:
28375 11:23:53 (0) ** DCOM: ............................................................................................................. 0.
28376 11:23:53 (0) ** WINMGMT: .......................................................................................................... 0.
28377 11:23:53 (0) ** WMIADAPTER: ....................................................................................................... 0.
28378 11:23:53 (0) **
28379 11:23:53 (0) ** 30 error(s) 0x80041002 - (WBEM_E_NOT_FOUND) Object cannot be found
28380 11:23:53 (0) ** => This error is typically a WMI error. This WMI error is due to:
28381 11:23:53 (0) ** - a missing WMI class definition or object.
28382 11:23:53 (0) ** (See any GET, ENUMERATION, EXECQUERY and GET VALUE operation failures).
28383 11:23:53 (0) ** You can correct the missing class definitions by:
28384 11:23:53 (0) ** - Manually recompiling the MOF file(s) with the 'MOFCOMP <FileName.MOF>' command.
28385 11:23:53 (0) ** Note: You can build a list of classes in relation with their WMI provider and MOF file with WMIDiag.
28386 11:23:53 (0) ** (This list can be built on a similar and working WMI Windows installation)
28387 11:23:53 (0) ** The following command line must be used:
28388 11:23:53 (0) ** i.e. 'WMIDiag CorrelateClassAndProvider'
28389 11:23:53 (0) ** Note: When a WMI performance class is missing, you can manually resynchronize performance counters
28390 11:23:53 (0) ** with WMI by starting the ADAP process.
28391 11:23:53 (0) ** - a WMI repository corruption.
28392 11:23:53 (0) ** In such a case, you must rerun WMIDiag with 'WriteInRepository' parameter
28393 11:23:53 (0) ** to validate the WMI repository operations.
28394 11:23:53 (0) ** Note: ENSURE you are an administrator with FULL access to WMI EVERY namespaces of the computer before
28395 11:23:53 (0) ** executing the WriteInRepository command. To write temporary data from the Root namespace, use:
28396 11:23:53 (0) ** i.e. 'WMIDiag WriteInRepository=Root'
28397 11:23:53 (0) ** - If the WriteInRepository command fails, while being an Administrator with ALL accesses to ALL namespaces
28398 11:23:53 (0) ** the WMI repository must be reconstructed.
28399 11:23:53 (0) ** Note: The WMI repository reconstruction requires to locate all MOF files needed to rebuild the repository,
28400 11:23:53 (0) ** otherwise some applications may fail after the reconstruction.
28401 11:23:53 (0) ** This can be achieved with the following command:
28402 11:23:53 (0) ** i.e. 'WMIDiag ShowMOFErrors'
28403 11:23:53 (0) ** Note: The repository reconstruction must be a LAST RESORT solution and ONLY after executing
28404 11:23:53 (0) ** ALL fixes previously mentioned.
28405 11:23:53 (2) !! WARNING: Static information stored by external applications in the repository will be LOST! (i.e. SMS Inventory)
28406 11:23:53 (0) **
28407 11:23:53 (0) ** ----------------------------------------------------------------------------------------------------------------------------------
28408 11:23:53 (0) ** Unexpected, wrong or missing registry key values: ................................................................... 1 KEY(S)!
28409 11:23:53 (0) ** INFO: Unexpected registry key value:
28410 11:23:53 (0) ** - Current: HKLM\SOFTWARE\Microsoft\WBEM\CIMOM\Logging (REG_SZ) -> 0
28411 11:23:53 (0) ** - Expected: HKLM\SOFTWARE\Microsoft\WBEM\CIMOM\Logging (REG_SZ) -> 1
28412 11:23:53 (0) ** From the command line, the registry configuration can be corrected with the following command:
28413 11:23:53 (0) ** i.e. 'REG.EXE Add "HKLM\SOFTWARE\Microsoft\WBEM\CIMOM" /v "Logging" /t "REG_SZ" /d "1" /f'
28414 11:23:53 (0) **
28415 11:23:53 (0) ** ----------------------------------------------------------------------------------------------------------------------------------
28416 11:23:53 (0) ** ----------------------------------------------------------------------------------------------------------------------------------
28417 11:23:53 (0) ** ----------------------------------------------------------------------------------------------------------------------------------
28418 11:23:53 (0) ** ----------------------------------------------------------------------------------------------------------------------------------
28419 11:23:53 (0) **
28420 11:23:53 (0) ** ----------------------------------------------------------------------------------------------------------------------------------
28421 11:23:53 (0) ** ------------------------------------------------------ WMI REPORT: END -----------------------------------------------------------
28422 11:23:53 (0) ** ----------------------------------------------------------------------------------------------------------------------------------
28423 11:23:53 (0) **
28424 11:23:53 (0) ** ERROR: WMIDiag detected issues that could prevent WMI to work properly!. Check 'C:\USERS\PISKUNOVDV\APPDATA\LOCAL\TEMP\WMIDIAG-V2.1_WIN7_.CLI.SP1.64_WSPISKUNOV1_2012.03.14_11.19.23.LOG' for details.
28425 11:23:53 (0) **
28426 11:23:53 (0) ** WMIDiag v2.1 ended on 14 марта 2012 г. at 11:23 (W:55 E:39 S:1).
Please contact us at support@lansweeper.com and provide us with screenshots of the following:
• Your web console landing page. You can access your landing page by clicking on the Lansweeper logo in the top left corner of the web console. Please show us the whole page.
• Lansweeper webpages of one or more machines you are having trouble scanning. Please show us the “Errors” section of the pages.
For easy reference, also include a link to this forum thread in your email.
