dr_sah
Hi to all.
I have problems with wmi access from other domain with no trust relations. I see in lansweepserver all PC, but without any info.
How can I modify WMI access, to see PC info. I tried WMI repair, but without success.
bye
6 REPLIES 6
dr_sah
well, i think I found what is wrong.
I changed Domain DNS name and Netbios name.
Now is working a little bit better.
See this page : http://www.lansweeper.com/kb/untrusted.aspx
The problem is most likely a dns problem
dr_sah
I found in log this:
servername The server is not operational.
dr_sah
hi,
I removed all scripts and lsclient.exe, and did like you tell.
So, now I can resolve and see other untrusted domain and all PCs, but in lansweeper nothinh happend.
I think that scan doesn't work. Is somwhere tool for manualy run scan in other domain?
bye
I have licence for premium version, so we can exclude this.
You need to set up the alternate credentials tab.
dr_sah
how can I modify script :
Set WshShell = CreateObject("WScript.Shell")
WshShell.run "%logonserver%\netlogon\lsclient.exe myserver",0
to add user and password inside, for logon ( DOMAIN\user and password).
That would solve my problems.
