weskurtz
Ok, first of all I am new to LS but I do have it installed and setup. I have the two test workstations connected via lsclient.
The problem is, one of them comes back all red. Not really reporting anything.
The other, which I am logged into as admin, comes back with a RPC/WMI error and I cannot do anything to it remotely, I can only view most of the stuff.
I tried to run the test connection on the one I am logged into as an admin, and it says it isn't allowed by the security policy even though I am doing on another computer which I am also logged into as admin, and it doesn't give me a problem.
Any help would be greatly appreciated.
Thanks,
Wes
You need to run the connectiontester from the server to the client.
If you have any errors, the knowledgebase can help you : http://www.lansweeper.com/kb/knowledgebase.aspx
About the remote control problem : did you changed the action to your remote control executable? Is it accessible in the correct path?
weskurtz
I had an issue with IE. However, I still cannot remote control the other computer, and I have this damn RPC/WMI error.
