Sebretian
Can't get the "Lansweeper Web Console" to work. Textbook install on a VM for testing. Server 2003 SP2, MS SQL Express 2005.
In the the SQL logs I get the error "Login failed for user 'lssqluser32'. The user is not associated with a trusted SQL Server connection. [CLIENT: <local machine>]"
On the Web Console I get
System.Data.SqlClient.SqlException: Login failed for user 'lssqluser32'. The user is not associated with a trusted SQL Server connection...
I'm don't work much with SQL so I don't know what the solution is to this.
Any suggestions?
Your sql server needs to be configured for sql authentication. (mixed authentication)
This is an example on how to change this in sql2000 : http://www.windowsecurity.com/articles/SQL_Server_2000_Authentication.html
