Connectors
Knowledge Base Articles
Connectwise Connector
The ConnectWise Connector enables seamless integration with the ConnectWise API to sync configurations, agreements, SLAs and tickets. It allows users to get, add and update configurations via actions and filters. The component key is connectwiseConne...
Writers by Community Manager
  • 255 Views
  • 0 comments
Okta Connector
Manage users, groups, applications, and authentication policies in Okta. Connections API Token Authenticate using an API token from your Okta Admin Console InputCommentsDefaultOkta DomainThe base URL for the Okta API. Depending on your cloud environm...
  • 331 Views
  • 0 comments
Guru Connector
Note on third‑party tools We aim to provide accurate and helpful details about third‑party tools, but we can’t guarantee that this information is always complete or up to date. If you notice any discrepancies, feel free ...
  • 299 Views
  • 0 comments
Workday
  • 265 Views
  • 0 comments
xAI Grok Connector
  • 874 Views
  • 0 comments
First Resonance ION Connector
  • 227 Views
  • 0 comments
Azure Cosmos DB Connector
  • 272 Views
  • 0 comments
Zoom Connector
  • 356 Views
  • 0 comments
Zoho Connector
  • 255 Views
  • 0 comments
Zip Connector
Provides utility methods for working with zip files Actions Compress Gzip Compress Gzip file InputCommentsDefaultFile DataFile to Gzip compress Decompress Gzip Decompress Gzip file InputCommentsDefaultGzip File DataGzip data to decompress Unzip Decom...
  • 199 Views
  • 0 comments
Zendesk Sell Connector
  • 278 Views
  • 0 comments
Zendesk Connector
  • 738 Views
  • 0 comments
Yoti Sign Connector
  • 281 Views
  • 0 comments
Xero Connector
  • 257 Views
  • 0 comments
WooCommerce Connector
  • 295 Views
  • 0 comments
WhatsApp Connector
  • 316 Views
  • 0 comments
Universal Webhook Connector
  • 246 Views
  • 0 comments
UUID Connector
Generate UUIDs and GUIDs Actions Generate UUID Generate a version 4 UUID / GUID InputCommentsDefaultLower / Upper Case UUIDlowerRemove dashes?false Nil/Empty UUID Return the nil / empty UUID (00000000-0000-0000-0000-000000000000)
  • 214 Views
  • 0 comments
Typeform Connector
  • 228 Views
  • 0 comments
Twilio Connector
  • 230 Views
  • 0 comments
