MHScott
Between 0730 and 0945 this morning (1/22/26), the list of available fields to filter an Asset List on has been greatly reduced, breaking many of my flows.
Is this temporary, or will filters need to be rewritten moving forward?
Indeed, there was an incident causing this issue. It was resolved yesterday, so it should be working again now. I tried your filter, and it worked on my side. Could you please test again on your end?
MHScott
Filter is not failing now, but not returning any results.  I see updates on the Status page that there is/was an issue.  Probably need to wait for things to stabilize.
Query is about as easy as it gets...
		conjunction: AND,
		conditions: [
				path: "asset.general.type",
				operator: LIKE,
				value: "Windows"
MHScott
Sorry, went out on PTO.  Everything is working again as expected.
Vicente_SC
Moderator
Moderator
We haven’t changed the asset filters (at least not intentionally) so this looks like a bug. Thanks for the heads‑up and for opening a ticket.
Could you share the filter conditions you’re using so we can try to reproduce the error on our side?
MHScott
Here is the error I started getting this morning.  I have also placed a ticket.
ClickHouseStatement error: Dictionary (`assets.asset_types_dict`) not found: While processing (siteId = '22ab50cd-4be6-43d8-b13e-2e2334a4117f') AND ((deletedEntity AS deleted) = false) AND ((dictGet(assets.asset_types_dict, 'assetTypeName', assetTypeKey) AS assetTypeName) ILIKE '%Windows%').
Forum
