AzrSB
I’m trying to create my first workflow, but instead of the number of records, I’m seeing some code in the output window. I’m following the tutorial steps exactly. Could you please guide me on how to troubleshoot this issue?
I have attached the screenshot as well.
Jacob_H
Hey AzrSB - that code in the output window is what you will get very familiar with and looks good in the screenshot...  if you click down one step in the test results to 'list assets' you will/should see your asset data in that right window with the code... each step outputs something that then is used for something else until you get finished.. kinda like a waterfall, or, like if you're making a Lansweeper Cloud report.  You can watch Esben's Pro-Tip https://community.lansweeper.com/t5/pro-tips/pro-tips-60-automations-in-lansweeper/ba-p/79124
also  you can watch my intune one as you can see me bumble around and explain how that output stuff works overall -  it's more boring than Esben's:  https://www.lansweeper.com/blog/pro-tips/intune-automations/
I'd suggest watching the videos.
Jacob_H
Forum
