tallpr24
i received an email saying i have to migrate or that my old flows will say "classic" but mine do not say classic.  i have 3 work flows, each with about 13 steps.
please advise.
8 REPLIES 8
tallpr24
i had migrated everything, and everything was working up until maybe 2 weeks ago.
tallpr24
flow charts stopped working again. looks like last time it ran was a few weeks ago. I didn't change anything. Please help.
Have you tried updating the LS connector? If you see the message "This connection is no longer available. Please reset and choose a different connection", try to update the LS connection and click on "reset". Please let us know if that resolves the issue.
tallpr24
are these 3 the new ones that were auto migrated?
That's right, the ones that don't have the "classic" label. They should correspond to the Flows inside the classic workflows. You can start from those new workflows and fix the errors you'll find. You can use the migration guide to help you with that task
tallpr24
ok, cool, so i dont have to remake everything?
No, no need to rewrite them. You'll get a copy of your classic workflows (if they have more than 3 steps), and you just need to adapt them to the new version. It should be, in general, an easy migration, but it depends on the type of actions you have in your workflows. You can find more details about what to change in the migration guide
Vicente_SC
Moderator
Moderator
Hi @tallpr24
Yes, I just sent another notification announcing that the Flow builder update will be done tomorrowhttps://community.lansweeper.com/t5/flow-builder-program/flow-builder-update-scheduled-for-tomorrow-....
Once the update finishes, you will see your classic workflows, which you should migrate if you want to keep them. You can find more information about how to migrate them here: https://community.lansweeper.com/t5/flow-builder-program/flow-builder-migration-guide/ba-p/84553
Forum
