aweston
I am looking to use LanSweeper to make an update to our computers registry. We need to add a key and string to correct a software glitch. I have not been able to find an example of how to setup the commands or if I really need to use a script to deploy the changes.
Any advise?
servicedesk
In this case you can create a comand step and use REG ADD
http://ss64.com/nt/reg.html
Bruce_B
As the other customer above me pointed out, the REG ADD command should do the trick here. We would recommend testing the command in a CMD first before using it in the deployment module. For more information on the deployment module you can check this section of our knowledgebase.
servicedesk
