‎08-10-2018 05:54 AM
‎10-19-2023 10:04 AM
I know it's been a long time now but here's the complete guide.
Deploying Lansweeper in AWS Using An RDS Database ... - Lansweeper Community - 71428
‎08-28-2018 11:58 AM
‎08-28-2018 11:27 AM
AWS - Microsoft SQL Server on Amazon RDS
Ref: Microsoft SQL Server Security
The Microsoft SQL Server database engine uses role-based security. The master user name you use when you create a DB instance is a SQL Server Authentication login that is a member of the processadmin, public, and setupadmin fixed server roles.
Any user who creates a database is assigned to the db_owner role for that database and has all database-level permissions except for those that are used for backups. Amazon RDS manages backups for you.
The following server-level roles are not currently available in Amazon RDS:
bulkadmin
dbcreator
diskadmin
securityadmin
serveradmin
sysadmin
The user performing the database installation must be a member of your SQL Server's sysadmin server role. When the installation has completed, the Lansweeper service and web console will connect to the database with a newly created SQL user called lansweeperuser, which only has access to the Lansweeper database.
‎08-10-2018 10:07 AM
