‎06-30-2023 07:53 PM
Good day,
I am trailing Lansweeper classic and trying to deploy the agent via Intune, is this possible without connecting to the cloud? it wants an agentkey see example below but cant see where to find
Install command = LsAgent-windows.exe --server LAN-001 --port 9524 --agentkey 4c2db649-014a-41f5-a01d-08950d7af --mode unattended
Uninstall command = "C:\Program Files (x86)\LansweeperAgent\uninstall.exe" --mode unattended
‎07-03-2023 11:20 AM
Hi, thanks for the information, will deploying with Intune work with the on-prem only Lansweeper?
‎06-30-2023 07:59 PM
Hey julianhaines
Thanks for using Lansweeper !
That key can be found in the local web console, under Scanning, LS Agent Scanning.
More information can be found here
https://www.lansweeper.com/pro-tips/deploying-lsagent-with-intune/
