Is there a simple way to normalise data per machine if on VPN ?
Is there a simple way to normalise data per machine if on VPN? My asset keeps changing the IP?
View Entire Topic
Riley
Solution
Our product team is exploring methods to enhance IP address detection, especially when using a VPN. However, correctly merging or consolidating the scanned data for assets that do not use the IP address as the unique key should not be an issue. More information on how Lansweeper uniquely identifies assets can be found here.
