In this month's Pro Tips, I do a deep dive into the improved Patch Tuesday audit and provide extra resources on how to create a dashboard for monitoring your Windows updates deployments. You can find it in the blog post.
I loved the section on charts. Is there anyway to just display all servers in the patch chart and reboot chart, rather than everything (workstations and servers) ?
I have tried playing around with the below, but no joy 😕
Case When tblComputersystem.Domainrole > 1 Then 'Server'
Hi, This is really useful and I have immediately setup a new 'Patch Tuesday' tab with the report and charts...
However it's become clear that you need to update the whole chart code each month (as you'd expect to do with the main report) and replace the top-and-tail code to make each chart work.
I think it's implied in your text but just leaving it alone fails to enumerate that months data and thus the two charts don't reflect the report - is there any way to fed from the report data, or make the charts work in another way so we don't have to replace all that code each month?
Great job as always though!
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
