Pro Tip 60 showcases the first practical examples of workflows in Lansweeper! See how automations can be used to create Slack notifications to get alerted when new devices are discovered or when they break compliance. You can find the details in the Pro Tips blog post.
3 Comments
shamerli
Would it be possible to not have slack notifications, but a workflow that does the same in Xurrent (former 4ME° whih is our ITSM tool and with which we have the integration setup ?
rinks
We don't use Slack, but would this process work with integrating into a Teams channel or Outlook email, or possibly into a HaloITSM ticket?
You can send the data to any platform and do with it what you want. However not every platform has a connector, which makes it easier. Outlook, Teams both have connectors, we do not have a connector for HaloITSM (maybe in the future?) or Xurrent. But it is possible to add your own API calls etc to connect it manually.
