‎03-30-2023 01:43 AM
Hey everyone,
Requesting some help with a report which can display the counts of our device warranties in a summary:
Out of Warranty | Count Amount
1 Year Warranty Remaining | Count Amount
2 Year Warranty Remaining | Count Amount
3 Year Warranty Remaining | Count Amount
Appreciate some help as the intention is for this to be converted into a chart for a pie chart widget.
Thanks in advance 🙂
Solved! Go to Solution.
‎03-31-2023 11:15 AM
This should get you started :
Select Top (1000000) Case
When DatePart(yyyy, tblAssetCustom.Warrantydate) Is Not Null Then
Concat(DatePart(yyyy, tblAssetCustom.Warrantydate) - DatePart(yyyy,
GetDate()), ' :Years Warranty Remaining')
End As Title,
Count(tblAssets.AssetName) As [Count Of Assets]
From tblAssetCustom
Inner Join tblAssets On tblAssetCustom.AssetID = tblAssets.AssetID
Left Outer Join tsysIPLocations On tsysIPLocations.LocationID =
tblAssets.LocationID
Group By Case
End
Order By [Count Of Assets]
‎04-02-2023 11:54 PM
Hi ASismey,
Thank you for your response, that code is perfect, i managed to get the data i needed to prior to your response using the query below, really appreciate your response its much appreciated.
Select Distinct Top (1000000) Year(tblAssetCustom.Warrantydate) As
WarrantyExpiry,
Count(tblAssets.AssetID) As Total
From tblAssetCustom
Where tblAssetCustom.Warrantydate > GetDate() And tblComputersystem.Domainrole <
2 And tblAssetCustom.State = 1
Group By Year(tblAssetCustom.Warrantydate)
Order By WarrantyExpiry
End As Title,
From tblAssetCustom
Group By Case
End
