DaveWard
Hi all thanks for taking the time to read this
I am trying to create a lansweeper report that only shows all desktops and laptops including some other fields which works but for some reason its also showing our VMWARE systems which I need to filter out please could anyone assist, I have crawled through the forums and have started to go crazy now
My report runs like this, I am unsure on how or where to add the excluded manufacturer VMware, Inc.
DaveWard
Hi Yes i did some searching around other topics and just did some copying and pasting until it worked hahaha bits and bats of other peoples reports but this gives me exactly what I need now so thanks to everyone
  tblAssets.Domain,
  tblAssets.Username,
  tblADusers.email As Email,
  tblAssetCustom.Manufacturer As Make,
  tblAssetCustom.Model As Model,
  tsysOS.OSname As OS,
  tblAssets.Lastseen,
  tblAssetCustom.Warrantydate As [Warranty Expiration],
  tblState.Statename As State,
  Case
    When tblPortableBattery.AssetID Is Null Then 'Desktop'
    Else 'Laptop'
  End As [Desktop/Laptop]
From tblAssets
  Left Join tsysOS On tsysOS.OScode = tblAssets.OScode
  Left Join tblADusers On tblADusers.Username = tblAssets.Username
      tblAssets.LocationID
  Left Join tblPortableBattery On tblAssets.AssetID = tblPortableBattery.AssetID
Where (tblAssetCustom.Model Is Null Or tblAssetCustom.Model = '' Or
    tblAssetCustom.Model Not Like '%Virtual%') And
  tsysOS.OSname Not Like '%win 20%%' And tblAssets.Lastseen Is Not Null And
  tblAssets.Lastseen <> '' And tsysAssetTypes.AssetTypename In ('Windows',
  'Windows CE', 'apple mac', 'linux')
Order By tblAssets.Domain,
  tblAssets.AssetName
rom
I usually just put "tblassetcustom.manufacturer not like '%VMware%'"  in the WHERE clause, to filter out vmware stuff, and I think you can do %Microsoft%' as well, at least for windows computers, to rule out virtual stuff for Hyper-V.
beacampos
Hello, @DaveWard , glad to hear you have been able to solve the problem. Would you mind sharing with our Community what was the solution? This will be valuable for others joining that face the same situation! thank you !
DaveWard
  tblAssets.Domain,
  tblAssets.Username,
  tblAssets.Lastseen,
  Case
    Else 'Laptop'
From tblAssets
  tblAssets.AssetName
beacampos
Hello @DaveWard that's great, thanks a lot for sharing 🙂
DaveWard
This can be closed now thank
Reports & Analytics
