hamilto5
I need to modify the built in report called Memory: Available slots. I need it to also tell me the version of MS Office installed on the machine also.
Many thanks
Please use the report below for the information you are after.
Select Top 1000000 tsysOS.Image As Icon,
tblAssets.AssetID,
tblAssets.AssetUnique,
tblAssets.Domain,
tsysOS.OSname,
Ceiling(tblPhysicalMemoryArray.MaxCapacity / 1024) As MaxCapacity,
tblAssets.Memory,
Cast(CorrectMemory.Used As numeric) As [Slots used],
tblPhysicalMemoryArray.MemoryDevices As [Slots available],
tblPhysicalMemoryArray.MemoryDevices - CorrectMemory.Used As [Slots free],
SubQuery.softwareName,
SubQuery.softwareVersion,
SubQuery.SoftwarePublisher
From tblAssets
Inner Join tblPhysicalMemoryArray On tblAssets.AssetID =
tblPhysicalMemoryArray.AssetID
Inner Join (Select tblAssets.AssetID,
Sum(Ceiling(tblPhysicalMemory.Capacity / 1024 / 1024)) As Memory,
Count(tblPhysicalMemory.Win32_PhysicalMemoryid) As Used
From tblAssets
Left Outer Join (TsysMemorytypes
Right Outer Join tblPhysicalMemory On TsysMemorytypes.Memorytype =
tblPhysicalMemory.MemoryType) On tblAssets.AssetID =
tblPhysicalMemory.AssetID
Group By tblAssets.AssetID,
Having tblPhysicalMemory.MemoryType <> 11) CorrectMemory
On CorrectMemory.AssetID = tblAssets.AssetID
Left Join (Select Top 1000000 tblSoftware.AssetID,
tblSoftwareUni.softwareName,
tblSoftware.softwareVersion,
tblSoftwareUni.SoftwarePublisher
From tblSoftware
Where tblSoftwareUni.softwareName Like '%microsoft office%') SubQuery
On SubQuery.AssetID = tblAssets.AssetID
Where tblPhysicalMemoryArray.[Use] = 3 And tblAssetCustom.State = 1
Order By tblPhysicalMemoryArray.MemoryDevices - CorrectMemory.Used Desc,
tblAssets.AssetName
tblAssets.AssetID,
tblAssets.Domain,
tsysOS.OSname,
tblAssets.Memory,
From tblAssets
From tblAssets
From tblSoftware
tblAssets.AssetName
hamilto5
V5
Which Lansweeper version are you using? 4.2 or 5.0?
Reports & Analytics
