Unfortunately, Lansweeper currently does not scan the GUID of Adobe Reader by default. We will however mark this topic as a feature request so that this may be scanned in a future Lansweeper version. Unfortunately we can't give an estimated release date for this feature.
In order to get the GUID of an Adobe Reader DC, you will have to use a custom registry scan. Abobe stores its GUID information in the following registries:
32 bit Windows: HKEY_LOCAL_MACHINE\SOFTWARE\Adobe\{application}\{version}\Installer\
64 bit Windows: HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Adobe\{application}\{version}\Installer\
With the valuename being "ENU_GUID"
Found here: https://www.adobe.com/devnet-docs/acrobatetk/tools/AdminGuide/identify.html
Once you have added a custom registry scan with the correct registry key you can create a report which gives back the software name, version and GUID scanned via custom registry scanning. We added an example report below (for 64 bit Windows) which should give back the GUID of Adobe Acrobat Reader DC. However, to only give back unique GUIDs you will have to perform some advanced SQL.
  tblAssets.AssetID,
  tblAssets.Domain,
  tblAssets.Firstseen,
  tblAssets.Lastseen,
  tblAssets.Lasttried,
  Case
    When SubQuery1.Valuename Is Not Null And SubQuery1.Valuename <>
    '' Then 'Yes' Else 'No' End As ValuenameFound,
  tblSoftwareUni.softwareName As Software,
  tblSoftware.softwareVersion As Version,
  SubQuery1.Value,
  SubQuery1.Regkey,
  SubQuery1.Valuename,
  SubQuery1.Lastchanged,
  tblSoftwareUni.SoftwarePublisher As Publisher
From tblAssets
  Left Join (Select Top 1000000 tblRegistry.AssetID,
    tblRegistry.Regkey,
    tblRegistry.Valuename,
    tblRegistry.Value,
    tblRegistry.Lastchanged
  From tblRegistry
  Where
    tblRegistry.Regkey Like
    '%SOFTWARE\WOW6432Node\Adobe\Acrobat Reader\DC\Installer' And
    tblRegistry.Valuename = 'ENU_GUID') SubQuery1 On SubQuery1.AssetID =
    tblAssets.AssetID
  Inner Join tblSoftware On tblAssets.AssetID = tblSoftware.AssetID
Where Case
  End = 'Yes' And tblSoftwareUni.softwareName Like 'Adobe Acrobat Reader DC%'
Order By tblSoftware.softwareVersion
