JohnLewis
Is there a way to generate a report for an UPS and "Estimated charge remaining" and "Estimated minutes remaining?"
Jeremy_D
Below are instructions on how to get the information you are after.
  • Hover the mouse over the Reports tab and select "Create new report".
  • Double-click on the tblUps database table from the table list on the right to add it to your report.
  • Check the following fields from the tblUps database table: tblUps.EstimatedChargeRemaining & tblUps.EstimatedMinutesRemaining, along with any other fields that you may find useful for this report.
  • Give your report a title and hit "Save & Run" button.
JohnLewis
Awesome! thank you!
Jeremy_D
Reports & Analytics
