script_kitty
I have LS on my network, the WOL feature doesn't work...Anyone else experience this issue?
script_kitty
Hey sorry for the late response. Ok yah so, its basically everything you said it shouldn't be if you wanna use the WOL feature so I guess I can scratch that one. Any sort of work around or nah?
thanks
SuperDaveAPK
Need a little more info. Is your network all on the same LAN and same IP range? I ask because, for the most part, WOL broadcast packets cannot be routed.
Reports & Analytics
