Nils
This page explains how to use Audit trail to monitor and export key user and system activity in your Lansweeper Site, helping you improve visibility, support compliance, and streamline audits.
Audit trail is a foundational security feature in Lansweeper Sites, designed to fill a key visibility gap in user activity monitoring. It enhances audit readiness by providing clear records of who did what and when, directly within your Lansweeper Site.
Lansweeper’s audit trails capture user actions across four key areas: configuration changes (e.g. discovery settings or site setup), inventory edits (e.g. manual asset updates), view exports or API access, and user logins. These events help ensure accountability and support internal or regulatory audits.
Audit trail data is stored securely for up to 12 months and includes user-identifiable actions, and can be exported for further analysis. Because the data may include personally identifiable information (PII), it's intended for compliance and internal audit use, not for routine support cases.
Export audit trail data
You can export audit data for reporting, review, or long‑term archival directly from within your Lansweeper Site.
To export a timeline of user and system activity in your Lansweeper Site:
  1. In your Lansweeper Site, go to Configuration > Audit trail
  2. Select Export audit trail.
  3. In the popup, select the file type.
  4. Select Export.
Export audit trail data via the Data API
For automated workflows, integrations, or advanced analytics, audit trail data can also be retrieved using the Lansweeper Data API.
The Data API includes a dedicated AuditTrail data type, allowing you to filter records by date or event type, retrieve detailed user information, and manage large datasets through built‑in pagination.
For technical details and schema definitions, check out the Types specification.
Audit trail events
Currently, audit trails are grouped into four main categories:
All plans have access to Site access, Accounts configuration, and Custom views. Inventory configuration is only available on Pro and higher plans. For more information on plans, check out the pricing page.
Site access
Tracks when users access your Lansweeper Site.
Endpoint Description
siteAccess
Tracks when a user accesses the site
Tracks changes to user roles, groups, scopes, and related permissions.
addRole
Creates a new user role
updateRole
Edits and updates an existing user role
deleteRole
Deletes a single role
deleteRoles
Deletes multiple roles in bulk
createScope
Creates a new permission scope
updateScope
Edits and updates an existing scope
deleteScope
Deletes a single scope
deleteScopes
Deletes multiple scopes in bulk
scopesBulkUpdate
Edits and updates multiple scopes in bulk
updateProfile
Edits and updates a user profile
deleteProfile
Deletes a single user profile
deleteProfiles
Deletes multiple profiles in bulk
leaveSite
Tracks when a Lansweeper user leaves the site
toggleBlockedAccount
Blocks or unblocks an account’s access to the site
createGroup
Creates a new account group
updateGroup
Edits and updates an account group
deleteGroups
Deletes multiple account groups in bulk
deleteGroup
Deletes a single account group
Tracks updates to asset groups and inventory-related settings.
createAssetGroup
Creates a new asset group
updateAssetGroup
Edits and updates an asset group
deleteAssetGroup
Deletes a single asset group
createManyAssetGroups
Creates multiple asset groups in bulk
updateManyAssetGroups
Edits and updates multiple asset groups in bulk
deleteManyAssetGroups
Deletes multiple asset groups
mergeAssetGroups
Merges two asset groups
createAssetRelations
Creates an asset relation between assets or between an asset and a user
updateAssetCleanUpRules
Edits and updates asset cleanup rules
createAssetStates
Creates new asset states
updateAssetStates
Edits and updates asset states
deleteAssetStates
Deletes asset states
updateIpLocations
Edits and updates IP locations
deleteIpLocations
Deletes IP locations
createIpLocations
Creates new IP locations
deleteAsset
deleteAssets
Deletes multiple assets in bulk
resolveDedupConflict
Resolves asset duplicates, only keeping a single record in the inventory
createAssetV2
Creates a new asset
updateAssetV2
Updates an asset
createAssetRelationTypes
Creates new asset relation types
updateAssetRelationTypes
Edits and updates asset relation types
deleteAssetRelationTypes
Delete asset relation types
launchAssetOperation
Executes a bulk operation on assets
bulkEditAssets
Edits multiple assets in bulk (deprecated)
bulkDeleteAssets
Deletes multiple assets in bulk (deprecated)
securedBulkEditAssets
Securely edits multiple assets in bulk
securedBulkDeleteAssets
Securely deletes multiple assets in bulk
securedBulkDeleteUsers
Securely deletes multiple users in bulk
launchUserOperation
Executes a bulk operation on users
manageAssetTypes
Creates, edits or deletes asset types
createAssetTypes
Creates multiple asset types in bulk
updateAssetTypes
Edits and updates multiple asset types in bulk
deleteAssetTypes
Deletes multiple asset types in bulk
assetsResync
Forces resynchronization of one or more assets
createAzureCloudScanningTarget
Creates an Azure cloud scanning target
updateAzureCloudScanningTarget
Edits and updates an Azure cloud scanning target
deleteAzureCloudScanningTarget
Deletes a single Azure cloud scanning target
createAdUserPathScanningTarget
Creates an AD user path scanning target
updateAdUserPathScanningTarget
Edits and updates an AD user path scanning target
deleteAdUserPathScanningTarget
Deletes a single AD user path scanning target
createAwsRegionScanningTarget
Creates an AWS region scanning target
updateAwsRegionScanningTarget
Edits and updates an AWS region scanning target
deleteAwsRegionScanningTarget
Deletes a single AWS region scanning target
createIntuneV2ScanningTarget
Creates an Intune scanning target
updateIntuneV2ScanningTarget
Edits and updates an Intune scanning target
deleteIntuneV2ScanningTarget
Deletes a single Intune scanning target
Data extraction
Tracks when users export views.
exportView
Exports all data from a selected view, including filters and query
‎10-31-2025 11:31 AM
