Dan
I am trying to get actions working and am having a few problems.
I have created a folder called actions$ on the server, and shared it. (and put all the actions tools in it)
Updated the custom actions in the console with:
cmd.exe /K \\server\Actions$\uptime.exe {computer} /s
But when I click on Computer uptime from my workstation, nothing happens.
When I hover over the Computer uptime icon the following is displayed
javascript:runapp ('cmd.exe /k \\\\server\\action$\\uptime.exe coputer /s','false' (extra \\ put in?)
Error message for web page is displayed at the bottom right.....
Line: 270
Char: 3
Error: Automation server can't create object
Code: 0
URL: http://server/lansweeper31/default.aspx?
item=compdetail&comp=computer
Have I missed something in setting up the actions? Or Lansweeper31?
7 REPLIES 7
Dan
Dan
Sorted, played around with the secuirty settings untill it worked 🙂
Dan
Change internet security on server, ping works... access deined for computer uptime. No joy from workstation, even though I've change security settings.
Dan
Dropped security to low for trusted sites on both server and workstation. I'm sure some of the actions like ping worked yesterday, now even that won't work. On the server there is a page error: 'AjaxControlToolkit' is undefined.
You need to change the active-x settings on the computer where you are running internet explorer (also check your active-x settings for this zone)
Dan
Already done that, both on my work station and on server.
You need to adjust your internet explorer security settings (see the documentation)
Adding the site to the trusted zones should do the trick.
