ERoss
Is the default device view customizable?
Default view contains below content, but I would like to see 'barcode' without clicking the 'edit device details' button
Regards
State: Active
Type: Switch
IP: 192.168.x.x
Name: ProCurve Switch 2610-48
Model: eHTTP v2.0
Vendor: Hewlett-Packard
IP location: xxxx
OID: 1.3.6.1.4.1.11.2.3.7
Http title: ProCurve Switch 2610-48 (J9088A)
Http server: eHTTP v2.0
Description:
ProCurve J9088A Switch 2610-48, revision R.11.98, ROM R.10.06 (/sw/code/build/nemo)
Asset pages cannot be modified. The Barcode field is only displayed if it actually contains data.
The "edit device details" button is a Lansweeper 4.2 button by the way. The latest Lansweeper version is 5.0. We recommend upgrading to 5.0 per the instructions on page 165 and beyond of our online documentation: http://www.lansweeper.com/documentation.pdf
Take a backup of your database prior to upgrading by right-clicking on the lansweeperdb database in SQL Server Management Studio and selecting Tasks/Back Up. (Note that you cannot modify 5.0 asset pages either.)
ERoss
Thank you, I appreciate the response - I was not aware it would show if populated. I will experiment with that
