‎05-21-2010 12:16 AM
great product!...
I would like to know if there is a way to add/modify columns in the web console. More specifically in "computers in domain" page
By default I have "computer" "description" "os" "sp" .... I like to have the custom field "location"
Than you
bob
‎08-15-2010 04:54 AM
Thanks for asking a great question. After a small addition I was able to make necessary db adjustments to show what you are looking for. The only thing you missed was the actual JOIN on the tables at the bottom...I highlighted your correct code as well as the missing code below in red.
ALTER PROCEDURE [dbo].[Web40getdomain](@domain nvarchar(80))
AS SELECT dbo.Web40OSName.Compimage AS Icon, dbo.tblComputers.ComputerUnique, dbo.tblComputers.Computername,
dbo.Web40OSName.OSname AS OS, dbo.tblCompCustom.Location AS Location, dbo.tblComputers.Description AS Description, dbo.tblComputers.Username AS LastUser, dbo.Web40OSName.SP AS SP,
dbo.web40ProcessorCapacity.NrOfProcessors AS [Proc], dbo.web40ProcessorCapacity.MaxClockSpeed AS Speed, dbo.web40CorrectMemory.Memory,
dbo.tblComputers.LastknownIP AS IP, dbo.tblComputers.Lastseen
FROM dbo.tblComputers LEFT OUTER JOIN
dbo.web40allcompstates ON dbo.tblComputers.Computername = dbo.web40allcompstates.Computername LEFT OUTER JOIN
dbo.web40CorrectMemory ON dbo.tblComputers.Computername = dbo.web40CorrectMemory.Computername LEFT OUTER JOIN
dbo.Web40OSName ON dbo.tblComputers.Computername = dbo.Web40OSName.Computername LEFT OUTER JOIN
dbo.web40ProcessorCapacity ON dbo.tblComputers.Computername = dbo.web40ProcessorCapacity.Computername LEFT OUTER JOIN
dbo.tblComputersystem ON dbo.tblComputers.Computername = dbo.tblComputersystem.Computername LEFT OUTER JOIN
dbo.tblCompCustom ON dbo.tblComputers.Computername = dbo.tblCompCustom.Computername LEFT OUTER JOIN
dbo.tblOperatingsystem ON dbo.tblComputers.Computername = dbo.tblOperatingsystem.Computername
WHERE (dbo.tblComputers.Domain LIKE @domain)
It worked for me so hopefully it will work for you too. You asking in the first place helped me waste away a Saturday of making stored procedure changes!
Happy Coding
‎06-03-2010 04:11 PM
GO
/****** Object: StoredProcedure [dbo].[Web40getdomain] Script Date: 06/03/2010 08:09:32 ******/
SET ANSI_NULLS ON
GO
SET QUOTED_IDENTIFIER ON
GO
ORDER BY dbo.tblComputers.Computer
‎06-03-2010 12:23 AM
‎06-02-2010 06:08 PM
Msg 4104, Level 16, State 1, Procedure Web40getdomain, Line 3
The multi-part identifier "dbo.tblCompCustom.Location" could not be bound.
It seems like I cannot use custom fields... all the other ones work???
thank you
bob
‎06-02-2010 04:16 PM
‎06-02-2010 04:12 PM
Do you know the name of the table?
bob
‎06-02-2010 10:55 AM
but most likely you didn't join the correct table.
‎06-02-2010 12:51 AM
I have added :
in the Web40getdomain procedure but I get this error:
What am I doing wrong???
thank you
bob
‎05-21-2010 10:16 PM
