grandfinalemike
Is there a way to scan and capture the 'Conversion Status' or 'volumestatus' of a harddrive. I know that in the win32_encryptablevolume, the protection status is captured. But, we have found that with new surface devices, the drive comes encrypted, but not enabled. So the conversion status will show 'encrypted' but the protection status will show "protection off". When using a different drive encryption method other than bitlocker, gathering this information would be very helpful without having to log onto each device to get this information.
thanks
SouthySuper
This is the report I built for getting the "status on"
We have a GPO that points to a network share and the GPO creates this registry entry:
Registry key scan: SOFTWARE\Policies\Microsoft\FVE, valuename=DefaultRecoveryFolderPath
Which ADUC uses that same location to display the recovery key
Determining if the recovery key is actually stored there from lansweeper is rather difficult as those are priveledged attributes not normally visible from ADUC (unless you change the schema)
As far as the bitlocker encryption process there is a wmi call but i'm unable to find the MS link at the moment
Select Top 1000000 tsysAssetTypes.AssetTypeIcon16 As icon,
tblAssets.AssetID,
tblEncryptableVolume.DriveLetter,
Case When tblEncryptableVolume.ProtectionStatus = 0 Then 'OFF'
When tblEncryptableVolume.ProtectionStatus = 1 Then 'ON' Else 'UNKNOWN'
End As BitLockStatus,
tblEncryptableVolume.LastChanged,
tblAssets.Domain,
tblAssets.Username,
tblAssets.Userdomain,
tblAssets.IPAddress,
tblAssets.Description,
tblAssetCustom.Manufacturer,
tblAssetCustom.Model,
tblAssetCustom.Location,
tsysIPLocations.IPLocation,
tsysOS.OSname As OS,
tblAssets.SP As SP,
tblAssets.Firstseen,
tblAssets.Lastseen
From tblEncryptableVolume
Inner Join tblAssets On tblEncryptableVolume.AssetId = tblAssets.AssetID
Inner Join tsysAssetTypes On tblAssets.Assettype = tsysAssetTypes.AssetType
Left Join tsysIPLocations On tblAssets.LocationID = tsysIPLocations.LocationID
Where tblEncryptableVolume.ProtectionStatus = 1 And tblAssets.Assettype = -1
Order By tblAssets.AssetName
