crashcarr
I have about 15 machines that have no model, vendor or tag listed. All the other information is reported correctly and no errors in scanning. I know a couple of them were custom made machines but is there a way I can manually enter this information or is there another setting on the system I could change to populate these fields. Thanks, James
Most of the times the bios provides this information to windows.
Maybe you can enter these details in your bios. (not likely)
If this isn't possible your only option would be to use one of the custom fields.
