The report below gives back a list of Citrix guests with a XenStore data.
The report will only list assets when the following criteria are met:
  • You have Lansweeper 7.0 or higher.
  • There is Citrix guest XenStore data scanned.
  • The assets must be active.
tsysIPLocations.IPLocation,
tblCitrixHost.Name As Host,
tblCitrixPool.Name As Pool,
tblCitrixGuestExtraInfoTypes.Name,
tblCitrixGuestExtraInfo.[Key],
tblCitrixGuestExtraInfo.Value,
tblAssets.Firstseen,
tblAssets.Lastseen
From tblCitrixGuest
Inner Join tblAssets On tblAssets.AssetID = tblCitrixGuest.AssetID
tblAssets.LocationID
Inner Join tblCitrixHost On tblCitrixGuest.HostId = tblCitrixHost.HostId
Inner Join tblCitrixPool On tblCitrixPool.PoolId = tblCitrixHost.PoolId
Inner Join tblCitrixGuestExtraInfo On tblCitrixGuestExtraInfo.GuestId =
tblCitrixGuest.GuestId
Inner Join tblCitrixGuestExtraInfoTypes On
tblCitrixGuestExtraInfoTypes.InfoTypeId = tblCitrixGuestExtraInfo.InfoTypeId
Where tblCitrixGuestExtraInfoTypes.Name = 'XenStore data' And
tblState.Statename = 'Active'
Order By Pool,
Host,
tblAssets.AssetName
0 REPLIES 0
