The report below gives back a list of Citrix pool patch data.
The report will only list assets when the following criteria are met:
  • You have Lansweeper 7.0 or higher.
  • There is Citrix pool data scanned.
  • The assets must be active.
tblCitrixPool.LivePatching,
tblCitrixPool.PolicyNoVendorDevice,
tblCitrixPool.RedoLog,
tblCitrixPool.HighAvailability,
tblCitrixPool.HighAvailabilityAllowOvercommit,
tblCitrixPool.HighAvailabilityOvercommitted,
tblCitrixPool.WorkloadBalancing,
tblCitrixPool.WorkloadBalancingVerifyCert,
tblCitrixPoolPatch.Name,
tblCitrixPoolPatch.Size,
tblCitrixPoolPatch.Version,
tblCitrixPoolPatch.AfterApplyGuidance,
tblCitrixPoolPatch.Applied,
tblCitrixPoolPatch.Description,
tblAssets.Firstseen,
tblAssets.Lastseen
From tblCitrixPool
Inner Join tblAssets On tblAssets.AssetID = tblCitrixPool.AssetID
Inner Join tblCitrixPoolPatch On tblCitrixPoolPatch.PoolId =
tblCitrixPool.PoolId
Where tblState.Statename = 'Active'
Order By tblAssets.AssetName
0 REPLIES 0
