tom999
I have recently purchased the premium edition. One of the key things I want to do is create a custom report showing the Mcafee AV sig versions.
I have been trying to follow the previous thread here
http://www.lansweeper.com/forum/yaf_postst1450_Dsiplay-Anti-Virus-infomation.aspx
I added some custom registry keys pointing to the dat file version etc, but when I look in the report builder I can't see them?
I have attached some screen grabs.
Can anyone help?
thanks
tom999
I can see now the values are in the tbregistry, I was expecting them to come up on the tickbox options under the query1 tab (picture 2 above).
I will now go on to try to create the sql query
The info should be in the table tblregistry.
Your query should contain something like regvalue = 'AVdatversion'
First make a sample report :
select * from tblregistry
Then you will see what's in the table.
tom999
FYI I added the custom registy keys a few days ago and a number of users have logged on/off since then and the lansweeper server has also been restarted.
