Options
‎02-18-2016 08:51 PM
Not sure if this will be helpful for others but thought I would pass it along. We use DameWare Mini Remote Control and I used the following Action
"C:\Program Files\SolarWinds\DameWare Mini Remote Control 11.0 x64\DWRCC.exe" -c: -h: -m:{computer} -a:1
After searching for a computer you can then click on the Action for DameWare and this will automatically open DameWare and connect to the PC as with the Authentication of 'Windows NT Challenge/Response' and it will use the Current Loggon Credentials.
Below is information on the switches in the action
-c: Connects automatically
-h: Uses default connection settings
-m: Sets the machine or host name...I used {computer} which is pulled from Lansweeper as a command
-a: Specifies authentication method...0=Proprietary Challenge/Response, 1=NT Challenge/Response, 2=Encrypted Windows Logon, 3=Smart Card Logon
Nothing huge, just thought it might help someone else
Labels:
Custom Actions
Options
‎06-10-2016 03:50 PM
I get the file not found error message. Any idea why this is ? I doublechecked the path, and it does work in my explorer.
Options
‎05-30-2016 11:12 AM
My version ....
Use one version for all users.
{actionpath}\dw\DWRCC.exe -m:{computer} -d:Work.local -a:1
