sullivane
I have a deployment setup for DelProf2, a command line utility that deletes user profiles on a machine. It works on most of the computers, but sometimes it fails with "Result: Deployment ended: Incorrect function". I know the command is good, as it works on most. Also, if I copy the command from LS and run it on the machine manually, it works just fine.
Anyway to figure out that error better?
FYI for everyone: this issue was caused by a leading space in one of the package shares submitted under Deployment\Security Options. We'll automatically strip leading and trailing spaces in a future release.
I would recommend contacting support@lansweeper.com and providing:
  • Link to this forum thread.
  • Export of your deployment package.
  • Excel export of the entire Deployment\Logs page.
sullivane
I also created an asset action, using the scanning creds and psexec. That works fine as well. Same command as deployment.
sullivane
I am running it under scanning creds.
It's not succeeding, as all the user profiles stay.
I can remote into the computer using the scanning creds and run the same command just fine, just not as a deployment.
The deployment works fine on many other computers.
Daniel_B
A possible cause of this might be that you deployed the package under the System account. Try deploying under Scanning credentials. Generally, if you get an "Incorrect function" message, some error code was returned by the script which is not part of the success codes you have defined. Sometimes it might be enough to add all possible result codes of your script to the Success codes in your deployment step.
