rgito
I have installed lansweeper on an XP box (called Foo) in my cube.
I can get my management console to start just fine (using the default login account and password).
My digital dashboard USED to work, but now it fails with a
"You are not authorized to view this page. HTTP 401.1 - Unauthorized: Logon Failed"
My web link is pointing to: http://Foo/lansweeper32 as it always has.
Are there some simple things I can check to see what happened? IIS is running on my machine. I am logged in as administrator, just as I was when I installed the software.
This is so frustrating as everything was fine a week or so ago. Thanks for the help.
Something must have been changed.
Could you open your IIS and check that anonymous logon is enabled.
