dkrnetadmin wrote:
It no longer appears twice. And the workstation that appeared 9 times only shows up 3 times. Is this normal behavior? It seems to be cleaning itself of duplicate entries.
No, this is not normal behaviour, and so far you seem to be the only one with this problem.
Do your other clients with this problem also have the "System.Data.SqlClient.SqlException: Violation of PRIMARY KEY constraint 'PK_tblsyslastscan'." error?
