ERoss
All,
Can an IP location header be edited?? we are renumbering and splitting subnets, I can create a 'new' subnet, but can't seem to find how to edit the label of an existing one??
Cheers
Karel_DS
When you go to 'Configuration -> Asset groups' page, you'll have a table at the top of the page with the IP locations. When you click on the second-last icon in a table row you'll be able to edit it's name, IP range etc.
ifm wrote:
I just tried to add some new IP locations and get the error:
"Error while saving:
Data must be at least 1 character in length"
I do not want to add a deployment folder, username or password (this is a printers IP-range).
How can I make it save anyway?
Submitting a package share isn't required. We cannot reproduce the behavior you're describing. If the issue persists, please contact support@lansweeper.com and provide:
  • Screenshots of the steps you are taking to produce the behavior.
We haven't heard back from you regarding this issue, so we'll consider this resolved.
ifm
ERoss
Thank you Karel!!!
Karel_DS
