Merbecks
This action allows you to shutdown the spooler service, delete all files which should be printed and restart the service. It's usefull if the printer has paper jam and the user calls you with the comment 'My printer speeks only egyptian and uses a lot of pages' 🙂
{actionpath}killspooler.cmd {smartname}
You have to put the killspooler.cmd in your actionpath, also the psservice.exe (see Microsoft SysInternals)
@echo off
setlocal
if "%1"=="" goto Hilfe
if "%1"=="/?" goto Hilfe
if "%1"=="-?" goto Hilfe
if "%1"=="-h" goto Hilfe
if "%1"=="--h" goto Hilfe
if "%1"=="-help" goto Hilfe
if "%1"=="--help" goto Hilfe
set PSPATH=\\put\your\actionpath\here
set PC=%1
%PSPATH%\psservice.exe \\%PC% stop spooler
del \\%PC%\admin$\system32\spool\PRINTERS\*.* /Q
%PSPATH%\psservice.exe \\%PC% start spooler
goto Ende
:Hilfe
echo Dieses Skript leert die Druckerwarteschlange auf entfernten PC's
echo Bsp.: killspooler idv-2254
echo.
:Ende
0 REPLIES 0
