Ok I think I got it to run and I got this
Msg 2714, Level 16, State 6, Line 1
There is already an object named 'TsysConfig' in the database.
Msg 2714, Level 16, State 6, Line 2
There is already an object named 'TsysMemorytypes' in the database.
There is already an object named 'TsysSerials' in the database.
There is already an object named 'Tsysservicestatus' in the database.
There is already an object named 'tblCompCustom' in the database.
There is already an object named 'tblPhysicalMemory' in the database.
There is already an object named 'tblPhysicalMemoryArray' in the database.
There is already an object named 'tblstate' in the database.
There is already an object named 'tsysActiveScanDomains' in the database.
There is already an object named 'tsysActiveScanOU' in the database.
There is already an object named 'tsysDomainPasswords' in the database.
There is already an object named 'tblSerialnumber' in the database.
Msg 1779, Level 16, State 0, Line 2
Table 'tblSerialnumber' already has a primary key defined on it.
Msg 1750, Level 16, State 0, Line 2
Could not create constraint. See previous errors.
Msg 1781, Level 16, State 1, Line 2
Column already has a DEFAULT bound to it.
Msg 1767, Level 16, State 0, Line 2
Foreign key 'FK_tblSerialnumber_tblComputers' references invalid table 'dbo.tblComputers'.
Table 'TsysConfig' already has a primary key defined on it.
Table 'TsysMemorytypes' already has a primary key defined on it.
Table 'TsysSerials' already has a primary key defined on it.
Table 'Tsysservicestatus' already has a primary key defined on it.
Table 'tblCompCustom' already has a primary key defined on it.
Table 'tblPhysicalMemory' already has a primary key defined on it.
Table 'tblPhysicalMemoryArray' already has a primary key defined on it.
Table 'tblstate' already has a primary key defined on it.
Table 'tsysActiveScanDomains' already has a primary key defined on it.
Table 'tsysActiveScanOU' already has a primary key defined on it.
Table 'tsysDomainPasswords' already has a primary key defined on it.
Foreign key 'FK_tblPhysicalMemory_tblComputers' references invalid table 'dbo.tblComputers'.
Foreign key 'FK_tblPhysicalMemoryArray_tblComputers' references invalid table 'dbo.tblComputers'.
Msg 4902, Level 16, State 1, Line 2
Cannot alter table 'tblcomputers' because this table does not exist in database 'master'.
Cannot alter table 'tblsoftware' because this table does not exist in database 'master'.
Cannot alter table 'tblADComputers' because this table does not exist in database 'master'.
Msg 4902, Level 16, State 1, Line 1
Cannot alter table 'tblADusers' because this table does not exist in database 'master'.
Cannot alter table 'tblApprovedSoftware' because this table does not exist in database 'master'.
Msg 4902, Level 16, State 1, Line 3
Cannot alter table 'tblDesktop' because this table does not exist in database 'master'.
Cannot alter table 'tblDesktopMonitor' because this table does not exist in database 'master'.
Cannot alter table 'tblFloppy' because this table does not exist in database 'master'.
Cannot alter table 'tblGroups' because this table does not exist in database 'master'.
Cannot alter table 'tblIDEController' because this table does not exist in database 'master'.
Cannot alter table 'tblKeyboard' because this table does not exist in database 'master'.
Cannot alter table 'dbo.tblLicenses' because this table does not exist in database 'master'.
Cannot alter table 'tblLicenses' because this table does not exist in database 'master'.
Cannot alter table 'tblNetwork' because this table does not exist in database 'master'.
Cannot alter table 'tblNetworkClient' because this table does not exist in database 'master'.
Cannot alter table 'tblPointingDevice' because this table does not exist in database 'master'.
Cannot alter table 'tblPortConnector' because this table does not exist in database 'master'.
Cannot alter table 'tblPOTSModem' because this table does not exist in database 'master'.
Cannot alter table 'tblPrinters' because this table does not exist in database 'master'.
Cannot alter table 'tblPROCESSOR' because this table does not exist in database 'master'.
Cannot alter table 'tblSerialPort' because this table does not exist in database 'master'.
Cannot alter table 'tblServices' because this table does not exist in database 'master'.
Cannot alter table 'tblShares' because this table does not exist in database 'master'.
Msg 3701, Level 11, State 6, Line 2
Cannot drop the index 'tblSoftware.IX_tblSoftware', because it does not exist in the system catalog.
Cannot drop the index 'tblSoftware.tblSoftware30', because it does not exist in the system catalog.
Msg 208, Level 16, State 1, Line 2
Invalid object name 'tblsoftware'.
Cannot alter table 'tblSoftware' because this table does not exist in database 'master'.
Msg 1906, Level 11, State 1, Line 2
Cannot create an index on 'tblSoftware', because this table does not exist in database 'master'.
Cannot create an index on 'dbo.tblSoftware', because this table does not exist in database 'master'.
Cannot alter table 'dbo.tblApprovedSoftware' because this table does not exist in database 'master'.
Cannot alter table 'tblUSBController' because this table does not exist in database 'master'.
Cannot alter table 'tblUsers' because this table does not exist in database 'master'.
Msg 208, Level 16, State 1, Line 1
Invalid object name 'TsysWaittime'.
Msg 2627, Level 14, State 1, Line 1
Violation of PRIMARY KEY constraint 'PK_tsysSerials'. Cannot insert duplicate key in object 'TsysSerials'.
The statement has been terminated.
(0 row(s) affected)
(0 row(s) affected)
(0 row(s) affected)
(0 row(s) affected)
(0 row(s) affected)
(0 row(s) affected)
(0 row(s) affected)
(0 row(s) affected)
(0 row(s) affected)
(0 row(s) affected)
Violation of PRIMARY KEY constraint 'PK__TsysRamtypes__08961D2F'. Cannot insert duplicate key in object 'TsysMemorytypes'.
(0 row(s) affected)
(0 row(s) affected)
(0 row(s) affected)
(0 row(s) affected)
(0 row(s) affected)
(0 row(s) affected)
(0 row(s) affected)
(0 row(s) affected)
(0 row(s) affected)
(0 row(s) affected)
(0 row(s) affected)
(0 row(s) affected)
(0 row(s) affected)
(0 row(s) affected)
(0 row(s) affected)
(0 row(s) affected)
(0 row(s) affected)
(0 row(s) affected)
(0 row(s) affected)
(0 row(s) affected)
(0 row(s) affected)
(0 row(s) affected)
Violation of PRIMARY KEY constraint 'PK_TblsysConfig'. Cannot insert duplicate key in object 'TsysConfig'.
(0 row(s) affected)
Violation of PRIMARY KEY constraint 'PK_tblstate'. Cannot insert duplicate key in object 'tblstate'.
(0 row(s) affected)
(0 row(s) affected)
(0 row(s) affected)
(0 row(s) affected)
(0 row(s) affected)
(0 row(s) affected)
Msg 2714, Level 16, State 5, Procedure Web30customfields, Line 3
There is already an object named 'Web30customfields' in the database.
Msg 208, Level 16, State 1, Procedure Web30RepActiveComputers, Line 4
Invalid object name 'dbo.tblComputers'.
Msg 208, Level 16, State 1, Procedure web30repallcompstates, Line 4
Msg 2714, Level 16, State 5, Procedure web30getstate, Line 3
There is already an object named 'web30getstate' in the database.
Msg 208, Level 16, State 6, Procedure Web301comp, Line 3
Invalid object name 'dbo.Web301comp'.
Msg 208, Level 16, State 1, Procedure web30licensecompliance, Line 4
Invalid object name 'dbo.web30repUsedSoftware'.
Invalid object name 'dbo.tblLicenses'.
Msg 208, Level 16, State 1, Procedure web30alldomains, Line 4
Msg 208, Level 16, State 1, Procedure Web30totalnonactive, Line 5
Invalid object name 'dbo.web30repallcompstates'.
Msg 208, Level 16, State 1, Procedure Web30totalerror, Line 4
Invalid object name 'dbo.tblComputersystem'.
Msg 208, Level 16, State 1, Procedure web30totalClients, Line 4
Msg 208, Level 16, State 1, Procedure web30totalServers, Line 4
Msg 208, Level 16, State 1, Procedure web30totaldomain, Line 5
Invalid object name 'dbo.Web30totalnonactive'.
Invalid object name 'dbo.web30totalServers'.
Invalid object name 'dbo.Web30totalerror'.
Invalid object name 'dbo.web30totalClients'.
Msg 208, Level 16, State 6, Procedure Web30computers, Line 3
Invalid object name 'dbo.Web30computers'.
Msg 2714, Level 16, State 5, Procedure web30hwSerials, Line 3
There is already an object named 'web30hwSerials' in the database.
Msg 2714, Level 16, State 5, Procedure web30hwregistry, Line 3
There is already an object named 'web30hwregistry' in the database.
Msg 2714, Level 16, State 5, Procedure web30hwfile, Line 3
There is already an object named 'web30hwfile' in the database.
Msg 2714, Level 16, State 5, Procedure web30hwmemory, Line 3
There is already an object named 'web30hwmemory' in the database.
Msg 2714, Level 16, State 5, Procedure web30hwmemoryarray, Line 3
There is already an object named 'web30hwmemoryarray' in the database.
Cannot alter table 'tsysassetlinks' because this table does not exist in database 'master'.
