pharoz
I noticed the quicksearch doesn’t pick up the system’s name if I put in the full FQDN (pc.domain.org).
It works if I only put in the systems name or it’s IP address. Not sure if this is intentional?
PS. Great software BTW!
This is expected behavior. For performance reasons, the search bar only supports a limited number of fields, which are listed on page 85 of our online documentation: http://www.lansweeper.com/documentation.pdf
Note that you can create a custom report that lists the FQDN and filter the report within the report results to perform a "search". To create a basic report, open the report builder under Reports/Create New Report, tick the FQDN field in the tblAssets table, submit a report title and hit the Save & Run button.
