CyberCitizen
Honored Sweeper
Fuji Xerox SC2020 Detected As Router / Not Printer
Any suggestions? We initially filtered out most asset types but couldn't work out why the printers were not showing up. Turns out they are routers.
Device Tester can see the machine as well including the toners etc, however being as Lansweeper is detecting the device as a router, we can't see the toner.
Lansweeper DeviceTester 7.0.0.1
Status: Running
Version: 7.0.110.2
Pinging 10.30.161.10
Ping ok.
TTL: 61
Scanning TCP ports..
Open ports:
21 (FTP)
23 (Telnet)
80 (HTTP)
9100 (Jetdirect)
Closed ports:
22 (SSH)
25 (SMTP)
135 (EPMAP)
139 (NetBIOS Session Service)
443 (HTTPS)
445 (SMB)
16992 (Vpro HTTP)
16993 (Vpro HTTPS)
Scanning DNS..
Could not scan DNS.
Scanning netbios (UDP)..
Could not scan netbios
Scanning FTP..
220 FUJI XEROX DocuCentre SC2020
Scanning SIP..
Error: Socket exception TimedOut: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond
Scanning HTTP..
Url: Http://10.30.161.10
Response Uri: http://10.30.161.10/default.htm
Connection: close
Content-Length: 901
Content-Type: text/html
Server: EWS-NIC5/99.00
Title: Internet Services
Scanning SNMP..
ObjectID: 1.3.6.1.4.1.297.1.11.93.1.37.17.1.1
Toners:
1.3.6.1.2.1.43.11.1.1.2.1.1: 1
1.3.6.1.2.1.43.11.1.1.2.1.2: 1
1.3.6.1.2.1.43.11.1.1.2.1.3: 1
1.3.6.1.2.1.43.11.1.1.2.1.4: 1
1.3.6.1.2.1.43.11.1.1.2.1.5: 1
1.3.6.1.2.1.43.11.1.1.3.1.1: 1
1.3.6.1.2.1.43.11.1.1.3.1.2: 2
1.3.6.1.2.1.43.11.1.1.3.1.3: 3
1.3.6.1.2.1.43.11.1.1.3.1.4: 4
1.3.6.1.2.1.43.11.1.1.3.1.5: 0
1.3.6.1.2.1.43.11.1.1.4.1.1: 3
1.3.6.1.2.1.43.11.1.1.4.1.2: 3
1.3.6.1.2.1.43.11.1.1.4.1.3: 3
1.3.6.1.2.1.43.11.1.1.4.1.4: 3
1.3.6.1.2.1.43.11.1.1.4.1.5: 4
1.3.6.1.2.1.43.11.1.1.5.1.1: 3
1.3.6.1.2.1.43.11.1.1.5.1.2: 3
1.3.6.1.2.1.43.11.1.1.5.1.3: 3
1.3.6.1.2.1.43.11.1.1.5.1.4: 3
1.3.6.1.2.1.43.11.1.1.5.1.5: 4
1.3.6.1.2.1.43.11.1.1.6.1.1: Cyan Toner Cartridge
1.3.6.1.2.1.43.11.1.1.6.1.2: Magenta Toner Cartridge
1.3.6.1.2.1.43.11.1.1.6.1.3: Yellow Toner Cartridge
1.3.6.1.2.1.43.11.1.1.6.1.4: Black Toner Cartridge
1.3.6.1.2.1.43.11.1.1.6.1.5: Waste Toner Container [R5]
1.3.6.1.2.1.43.11.1.1.7.1.1: 7
1.3.6.1.2.1.43.11.1.1.7.1.2: 7
1.3.6.1.2.1.43.11.1.1.7.1.3: 7
1.3.6.1.2.1.43.11.1.1.7.1.4: 7
1.3.6.1.2.1.43.11.1.1.7.1.5: 7
1.3.6.1.2.1.43.11.1.1.8.1.1: 2500
1.3.6.1.2.1.43.11.1.1.8.1.2: 2500
1.3.6.1.2.1.43.11.1.1.8.1.3: 2500
1.3.6.1.2.1.43.11.1.1.8.1.4: 11000
1.3.6.1.2.1.43.11.1.1.8.1.5: 15000
1.3.6.1.2.1.43.11.1.1.9.1.1: 125
1.3.6.1.2.1.43.11.1.1.9.1.2: 250
1.3.6.1.2.1.43.11.1.1.9.1.3: 375
1.3.6.1.2.1.43.11.1.1.9.1.4: 11000
1.3.6.1.2.1.43.11.1.1.9.1.5: 8100
Scanning VPRO RMCPPing..
No reply to RMCP ping
Scanning DNS-SD..
No reply to DNS-SD
Scanning UPNP..
No reply to UPNP
Done.
Have you tried mapping the OID listed on the asset page to the printer asset type? https://www.lansweeper.com/knowledgebase/changing-an-assets-asset-type/#heading2
Thank you, that was exactly what I was after.
FYI
Fuji Xerox SC2020 - 1.3.6.1.4.1.297.1.11.93.1.37.17.1.1
