patrickleemart1
Is there a custom action I could create to display the contents of a specific directory on a target computer?
I use Clamwin for my antivirus and suspect files are moved to a quarantine directory. I get a report from each computer when a virus is detected and would like to view and delete files moved to quarantine. A custom action to launch a window to that standard directory would be nice.
Thanks for your help in advance...
patrickleemart1
That did it slimbyte...Thanks!
slimbyte
The explorer parameter is: /root,<object>
http://support.microsoft.com/kb/130510
the right way:
explorer.exe /root,\\{computername}\c$\some folder name
patrickleemart1
That command alone doesn't work. I'm thinking I would need to launch explorer.exe with a directory parameter, but haven't found the right command yet.
i_kulgu
maybe you can try ;
\\{computername}\c$\"directory to map"
