elledged
in which screen/area do you go in order to assign "Other Credentials" to assets? For example:
We have setup an SSH Credential with the name: Linux Boxes in /Configuration/Credentials;
However, the status on that page shows "Not in Use" and we can't seem to find where you would go in order to assign that credential to our Linux boxes.
Thanks.
-=UPDATE=-
I found it, but I would like to submit an enhancement request to make it easier to do this on a bulk basis. Right now, you have to use "Map Credential to One IP Address" for each system. Great for 2-3 systems, a pain for hundreds.
I would suggest a screen with all assets, or a subset thereof, that would have a checkbox you could check beside each; then, when selected, you could click a "Map Alternate Credentials" button and map it for all selected systems at once.
Go to configuration/scanning methods/IP Address range scanning.
Click on the green "+" icon after global credentials to add other credentials to this range.
