Dronic
Sometimes LS shows incorrect information about scanned computers (e.g. serial numbers or computer model is wrong). I understand that this mostly the vendor's fault because they did not enter the correct information in BIOS or wherever.
What is the best way to handle this? I can correct the information in the LS database but that would be overwritten after the next scan.
Thanks in advance.
If you update the bios with the correct information, lansweeper will update this on the next scan.
