cjmusa
Version 3.xx had been running so nicely it has been some time since I had to get to the configuration console and have forgotten how to do this.
Page 10 of the manual shows the login screen of the configuration console but doesn't say how to get to this logon screen. Is there a link on the Lansweeper Web Console that I am missing.
Also with regards to the premimum files that are downloaded - are these just coppied into the lansweeper subdirectory - say under program files if this is where one installs the latest version?
The instructions could be clearer.
Thanks.
The configuration tool is a link in your start menu/lansweeper and starts "lsmanage.exe"
The premium tools are stand alone executables and you can place them wherever you want.
