jrivet
I am currently running Lansweeper 4.0.0.27 to perform our inventory and I use Nagios 3.2.0 for host and service monitoring. Within the Nagios host and service detail pages I used to include a hyperlink to our lansweeper install that would take you directly to the machine in question. This was easily done with replacement variables like hostname and such. Now it seems that the indexing has changed because the url I used to use (e.g. http://lansweeper.mycompany.com/default.aspx?item=compdetail&comp=mycomputername) no longer works. It appears that the search function requires the "comp=" to be the id number assigned to that computer record . So my question is this, is there a way to format a URL to link to specific computer detail pages without knowing the computer ID# (comp field)?
Thank you.
try: default.aspx?item=quicksearch&q=pcname
