DesktopSupport
After a period of testing Lansweeper on a trail key, we have just purchased a premium licence.
Currently our Lansweeper (v5043) is running on a test PC (using MSSQL 2008 express)
We need to shift this now onto a proper server, how would you recommend we do it?
I was thinking, install MSSQL 2008 express onto the server, load lansweeper onto the server than perform SQL backup on old PC and restore onto server?
Will that work... are there any other steps I need to do, will I loose the custom reports and lansweeper config we currently have on the test PC?
Instructions on how to move your Lansweeper installation can be found here.
Reports and settings are stored in your database, so these will be moved along with your data.
