mwhitese
I am getting the following application event error when trying to start the lansweeper server:
Service cannot be started. System.TypeInitializationException: The type initializer for 'LansweeperService.starter' threw an exception. ---> System.TypeInitializationException: The type initializer for 'System.Data.SqlClient.SqlConnection' threw an exception. ---> System.TypeInitializationException: The type initializer for 'System.Data.SqlClient.SqlConnectionFactory' threw an exception. ---> System.TypeInitializationException: The type initializer for 'System.Data.SqlClient.SqlPerformanceCounters' threw an exception. ---> System.Configuration.ConfigurationErrorsException: Configuration system failed to initialize ---> System.Configuration.ConfigurationErrorsException: Unrecognized configuration section system.serviceModel. (c:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Config\machine.config line 146)
at System.Configuration.ConfigurationSchemaErrors.ThrowIfErrors(Boolean ignoreLocal)
at System.Configuration.BaseConfigurationRecord.ThrowIfParseErrors(ConfigurationSchemaErrors schemaErrors)
at System.Configuration.BaseCon...
For more information, see Help and Support Center at
Does anyone know how to resolve this problem?
You are the first one to report this error.
From what I can find it seems to be related to a corrupt dotnet framework installations.
http://weblogs.asp.net/bhouse/archive/2005/11/10/430270.aspx
http://geekswithblogs.net/mnf/archive/2008/11/14/could-not-load-type-system.servicemodel.configurati...
Most likely the "ServiceModelReg.exe /i" will fix your problem.
