ThomasC
We have some remote users who are not always on the corporate network because they have to VPN in. If I could get a script to run on their machines after they log into the VPN is there a way to have a computer offer its info to the lansweeper server.
I was trying to get lsclient.exe to work but I am having a bit of trouble. Mainly I do not think that a computer's info is updating when I use lsclient.exe on a remote machine, although it reports it has successfully connected to the server.
I have heard repeatedly that I do not have to use lsclient.exe in the premium version. My question is, after I upgrade to the premium version does lsclient.exe stop working? Is there any special configuration that need to be set up so that I can get lsclient.exe to start working?
Ideally I want lansweeper to use both methods, scan the network using WMI and for computers that get missed because they are off or remote get updated when they run domain logon scripts.
Lsclient still works.
Can you check for rpc errors after the lsclient connection.
